Ignition Point Sensor, will not start.
  • terrybullwon
    • Mar 2006
    • 8782
    What a couple of weeks, ignition switch is all wired in and working fine, turbo timmer has been binned
    But i drove down the road and back, she made excellent boost and pull then the turbo would spool up and the trottle body would not open, just lots of boost and no power to the wheels.
    Pulled the fault codes and got
    Tuesday, 13 March 2007, 12:30:09
    VAG-COM Version: Release 409.1-S
    Control Module Part Number: 895 907 404 BA
    Component and/or Version: MOTOR PMC 1
    Software Coding: 0261200484
    Work Shop Code: 1267356560
    5 Faults Found:
    00516 - Closed Throttle (Idle) Position Switch (F60)
    30-00 - Open or Short to B+
    00513 - Shareware Version. To Decode all DTCs
    27-10 - Please Register/Activate - Intermittent
    00515 - Shareware Version. To Decode all DTCs
    20-10 - Please Register/Activate - Intermittent
    00514 - Ignition Point Sensor (G4)
    03-10 - No Signal - Intermittent
    03-00 - Please Register/Activate
    Tuesday, 13 March 2007, 12:45:13
    2 Faults Found:
    03-00 - No Signal
    I have searched G4 and igniton point sensor but nothing.......
    Please help guys i am almost at the point of breaking
    Chef
  • terrybullwon
    • Mar 2006
    • 8782
    Just a stab in the dark, the dizzy is dead??????
    Chef
    • Jas11n
      • 5067
      James, I posted up the manual info for code 00513 yesterday.
      See the bottom of this thread >>> here
      Have you got the connectors for the G28 speed sensor and the engine timing sensor G4 mixed up?
      2001 Avus Silver B5 RS4.
      1995 S2 Coupe - sold (sniff)
      • terrybullwon
        • Mar 2006
        • 8782
        Thanks Jas, Mixed up? Do you mean pluged in the wrong connections? or my diagnostic?Vag com pic
        I dont think they could be pluged in the wrong way around because i made it down the road and stalled it turning into my drive after having to fit it to keep it going
        How bigger job is the dizzy??
        Cheers James
        Chef
        • Jas11n
          • 5067
          If the dizzy was dead, won't you expect a hallsender code?
          It just seems strange that both those above codes are showing, and the connectors are sited next to each other. I think (not 100%) that both the G4 and the G28 sensors are sited next to each other too.
          Hard for me, because the manual info I have is ABY based and not 3B, ie I'm not 100% sure if they are the same.
          • terrybullwon
            • Mar 2006
            • 8782
            Do they feed back to the ignition switch by any chance????
            If this is the case i may have made a mistake some where along the lines?
            Chef
            • terrybullwon
              • Mar 2006
              • 8782
              Parts men alike...... 034 905 381 is this the sensor i may require?
              Cheers James
              Chef
              • terrybullwon
                • Mar 2006
                • 8782
                HELP
                Almost two weeks have almost past to get this sensor to me from euro car parts.
                Today i put the brand new sensor in (G4 ignition point sensor) And i try to start the car again with the catch tank and every thing off just incase it does not work again
                Nothing just turns and turns..... Vag com shows the same fault
                Where would i find the readings across the 3pins on the sensor? I have tested it and i have numbers......... But the ecu still has no signal!?
                Help please
                Chef
                • Flat on my back
                  • Jan 2007
                  • 2449
                  If you still think its the G4 sensor, and now its replaced you'll have to check from the loom connection to the ECU eg. for shorts and open circuits.
                  Good luck.
                  Or if you can get hold of a digi oscilloscope you can see exactly what is or isn't working.
                  Carlos.
                  • terrybullwon
                    • Mar 2006
                    • 8782
                    Good luck.
                    Why me
                    Chef
                    • terrybullwon
                      • Mar 2006
                      • 8782
                      Sensor full tested,
                      Its sending a signal to the ecu.
                      If the code is cleared it still returns and fails to start!?
                      My next question is what do i do next?
                      Has any one got a 3B ecu laying about that i could test on my car?
                      Also in my limited time off work shall i check the timming? If this could be a contruibting factor?
                      Cheers James
                      Chef
                      • terrybullwon
                        • Mar 2006
                        • 8782
                        Balls!!!!!
                        Ece tested to the full by Iam Jemo, hit 22psi of boost in 1st iirc
                        2nd crank sensor from euro car parts now in and still throwing up the same fault code
                        Shall i bite the bullet and try a oem one at £70 ?
                        We have tested the plugs for a spark and nothing...... could this be the hall sender?
                        Any other sugestions are welcome as i have now hit a dead end.........
                        Cheers James
                        Chef
                        • GT500
                          • Jun 2006
                          • 2181
                          has the flywheel pin disappeared?
                          If its not there it won't run.
                          you can see by removing the starter.
                          Rob..
                          87 UR 20v ABY
                          97 S6 Avant
                          • terrybullwon
                            • Mar 2006
                            • 8782
                            Guess its worth a look
                            Thanks Rob,
                            I was linked to this as well http://www.picotech.com/auto/audi.html
                            Chef
                            • john881000
                              • May 2004
                              • 598
                              dizzy
                              hi James
                              did the distribitor test ok??
                              did i send simple instructions to you??
                              if not......sorry
                              will find again and send
                              cheers
                              john
