What a couple of weeks, ignition switch is all wired in and working fine, turbo timmer has been binned But i drove down the road and back, she made excellent boost and pull then the turbo would spool up and the trottle body would not open, just lots of boost and no power to the wheels.
Pulled the fault codes and got
Tuesday, 13 March 2007, 12:30:09
VAG-COM Version: Release 409.1-S
Control Module Part Number: 895 907 404 BA
Component and/or Version: MOTOR PMC 1
Software Coding: 0261200484
Work Shop Code: 1267356560
5 Faults Found:
00516 - Closed Throttle (Idle) Position Switch (F60)
30-00 - Open or Short to B+
00513 - Shareware Version. To Decode all DTCs
27-10 - Please Register/Activate - Intermittent
00515 - Shareware Version. To Decode all DTCs
20-10 - Please Register/Activate - Intermittent
00514 - Ignition Point Sensor (G4)
03-10 - No Signal - Intermittent
03-00 - Please Register/Activate
Tuesday, 13 March 2007, 12:45:13
2 Faults Found:
03-00 - No Signal
I have searched G4 and igniton point sensor but nothing.......
Please help guys i am almost at the point of breaking
Do they feed back to the ignition switch by any chance????
