Rotor arm BOSCH number urgently needed
  • auditude
    • 407
    It's possible to file the wider rotor down to the correct width. I haven't tried it myself, but it should be fine.
    Kenneth
    1990 Coupe quattro
    1991 200q20v x 2
    1985 4ksq 20vt project
    1986 Coupe GT 10vt project
    2006 Honda Ridgeline
    1998 Honda VFR800FI
    • kwlw
      • Sep 2004
      • 1025
      • Country: Lithuania
      You don't need to file whole rotor arm (you would have balancing problems then) - just the copper part. Just cut ends with sharp file, or metal saw blade. 5 minute job.
      Sau
      • steverrquattro
        • Oct 2006
        • 787
        I followed the advice of this thread and still ended up with a rotor arm which measured 18mm!!! Having said that, I did get it from GSF.
        They have now given me one from a Mercedes which measures 10.65mm. The question is, will this be too small???
        Link to part: http://www.gsfcarparts.com/922me0030
        Steve
        1990 RR 20V
        1982 SWB UR - RS2 Engine
        • Pirvu Eugen
          • Apr 2007
          • 1978
          • Country: Romania
          http://www.ebay.com.au/itm/1x-Bosch-...ht_2049wt_1195
          • Pirvu Eugen
            • Apr 2007
            • 1978
            • Country: Romania
            #20
            look here... it shows the right pn from the rotor.... i ordered this and i receive'd the right one... hope this helps! http://www.google.ro/imgres?q=123433...26&tx=36&ty=40
            • Pirvu Eugen
              • Apr 2007
              • 1978
              • Country: Romania
              #21
              They have now given me one from a Mercedes which measures 10mm. The question is, will this be too small???
              It has to have smaller tip for the high rpm...to reduce the spark hop issues.
              Iff the mercedes one has 1kohm resistor...then is ok..
              • steverrquattro
                • Oct 2006
                • 787
                The BOSCH number on the BERU part is 1234 332 215.
                Steve
                1990 RR 20V
                • stocious
                  • Jul 2012
                  • 838
                  toyota one in mine , but it most likely wont be in stock if you go to a stealers.
                  1991 S2 3B Coupe, KW v1, solid sub frames, poly bushed, chipped, about 260 ish
                  • AndyP
                    • 6049
                    For reference, these are available again from Bosch, but the rotor arm has gone up in price considerably!
                    1234 332 414 Rotor arm £16.49
                    1235 522 405 Dizzy cap £16.38
