Turbonetics experiences ??
  • breitling
    • Dec 2005
    • 491
    • Country: Norway
    Anyone in here with this one ?
    Looks like this is the one for me on the RS2 . Curiuos about spool up time,HP and NM etc.
    Turbonetics T3/T4 E-60, steg 5 ca. 550hp 0.82ar, T3
    Together with:
    -larger fmic/open air filter, larger maf 4" (?)Lmm
    -7a cams
    -Wiseco pistons 82,5 bore (8,5:1 comp)
    -H-profile rods with ARP 2000
    -Porsche GT2 fuel (550cc)
    -044 fuel pump
    -Tubular ex manifold,with T04 Flange 3"downpipe and all the way with 1 racekat
    -1,9 bar WG spring
    -Forge valve
    -N75 Race modified valve/solenoid
    -Custom motronic map
    Is it possible to reach the 500 barrier with this ?
    Audi RS4+Long sportquattro
    www.hansenmotorsport.no
  • +500hp
    • Dec 2004
    • 51
    Hi,
    yes it is possible.
    Probably you will need bigger IC beacuse I doubt original rs2 will do.
    an of course good setup - if you will stick with motronic SQ LMM would help(90mm).
    Otherwise other stuff you wrote should be good enough.
    Ed
    • breitling
      • Dec 2005
      • 491
      • Country: Norway
      its here :
      Trying to find the best suitable turbo that will start boost as early as possible-
      but i hav T04 or T4 flange on my ex tubular manifold... and all the good turbos doesnt come with that ..
      • jogi730
        • 2335
        Running Turbonetics T61 with T4 flange.
        Statrs spooling around 3500 and really on song at 4k.... then just pulls...... and pulls..... and pulls!
        Chris
        Audi 90 quattro (Typ 85)
        20v turbo conversion
        • AndyP
          • 6049
          Who or what is involved in 'race modifying' the N75 valve?
            N75 with the suffix J on end.
            • A80Avant
              • Sep 2005
              • 10873
              • Country: Greece
              a friend of mine has a turbonetics turbo now with K26 hotside especially made for the RS2,he has 354Hp at the wheels and 1.9bar over with 1.7bar steady boost.It really enters the play from 4000rpm and he is not happy with it anymore(he also has 2.4motor with larger pistons),so he is thinking of the GT3071R
              • breitling
                • Dec 2005
                • 491
                • Country: Norway
                i think its N75 with the suffix K on end.
                Anyone else with turbo experience . Really need some help here ..
                • breitling
                  • Dec 2005
                  • 491
                  • Country: Norway
                  4000rpm is legally late 3500-3800 would be great.
