Rotor arm advice needed
  • LHD_Kid
    • May 2006
    • 3695
    OK, so I have been sent a new rotor arm, to replace the narrow tipped one on my 3B...
    The old tip appears to be around 10mm wide, but the one I have been sent is around 18mm
    I know the 7A one is even wider, I understand this one might be from a Polo or something.
    The 18mm arm has part number 052 905 225 C
    Should I use this wide one? Should I cut a couple of mm off each side of the tip, to make it smaller?
    Where should I get a narrow one? (bearing in mind this wider one came from Vagparts)
    Anyone have a number for a 10mm tip rotor arm?
    Any advice gratefully received
    Chris
  • 4WheelDrifter
    • Oct 2004
    • 5773
    • Country: Devon
    Toyota P/N 19102-02020 for the 'correct' narrow tipped rotor. Or you can file/cut the wide one to suit.
    SS
    • LHD_Kid
      • May 2006
      • 3695
      Hmmmm, not sure where I could find somewhere to buy a Toyota one from.... I reckon that would be the best idea though...
      I will have a go at trimming the wider one down tomorrow, and see what it looks like once its done....!
      Anybody got any reasons why this would not be a good idea?
      Thanks for the advice,
      Chris
      • Pirvu Eugen
        • Apr 2007
        • 1978
        • Country: Romania
        052 905 414c Audi part number for rotor 11mm wide. I have took mine from Augsburg int.
        • LHD_Kid
          • May 2006
          • 3695
          Thanks, I will keep hold of the number for future, I ended up getting a wider one and trimming it down to size.....
          Chris
