OK, so I have been sent a new rotor arm, to replace the narrow tipped one on my 3B...
The old tip appears to be around 10mm wide, but the one I have been sent is around 18mm
I know the 7A one is even wider, I understand this one might be from a Polo or something.
The 18mm arm has part number 052 905 225 C
Should I use this wide one? Should I cut a couple of mm off each side of the tip, to make it smaller?
Where should I get a narrow one? (bearing in mind this wider one came from Vagparts)
Anyone have a number for a 10mm tip rotor arm?
Any advice gratefully received
Chris
Chris
