RR Turbo?
  • Jas11n
    • 5067
    RR Turbo?
    I have a mate who wants to get his K24 turbo rebuilt (1993 ABY) and he wants to know if the URquattro's RR turbo is the same? I know the RR engine is very similar to the 3B engine, but FA shows a slight difference of part number for the RR turbo.
    3B/ABY = 034 145 702,
    RR = 034 145 703 A.
    Would an RR turbo be ok to use for a rebuild then swap onto his ABY?
    TIA
    Jas..
    2001 Avus Silver B5 RS4.
    1995 S2 Coupe - sold (sniff)
  • Jas11n
    • 5067
    Anyone? Is this a dead end idea?
    • baltiboyS2
      • 965
      I am no 100% sure but is the rr turbo only oil cooled not both water and oil like the s2 and many other audis later on i could be wrong
      Raj Aby
      • Jas11n
        • 5067
        That did cross my mind, but the FA shows both oil feed and return lines along with water feed and return lines. So it looks to be water cooled.
        Jas..
        • martinjs
          • 3205
          Yes they are water cooled, and are the same as the S2 turbo.
          • Jas11n
            • 5067
            You'll do for me Martin. Thanks very much mate, I'll let the chap know
            Jas..
            • audiman
              • 4827
              i second martin. sure the turbos are the same, dont know why the pn is different
              Tom C - www.rcmr.co.uk
              Audi UR Quattro
              Audi 100 C3 2.0 5 cyl 115ps
              Audi B5 RS4 645ps 911nm
              • kwlw
                • Sep 2004
                • 1025
                • Country: Lithuania
                I think I know. They maybe have different cold side orientation due to different intercooler hoses route in the ur body. This can be easily adjusted by carefully taking cold side off, rotating, and tightening bolts back. I don't recommend loosen the bolts then rotating cold side while it is on the manifold. I have personally seen cut cold side seal after such operation (on K26). Maybe it happened because substantial force was needed to turn the cold side, and something went wrong so guy had tiny, but boost leak, which was fixed after one drop of some gasket sealant (non silicone!).
                Sau
