Technical Spec's
  • Phat HS2
    • Apr 2007
    • 14
    Technical Spec's
    Does anyone know the technical spec for a K24 turbo on my S2 Avant?? I have no details about it and wish to get some knowledge...
    In addition, my S2 Avant is 2226cc (original no mod's) what is the engine output in kW??
    Phat HS2
    :mischeif:
  • Jas11n
    • 5067
    Specs of the turbo, no idea but I'm sure the turbo chaps in here will know.
    Engine ouput for an ABY in KW is 169.
    Jas..
    2001 Avus Silver B5 RS4.
    1995 S2 Coupe - sold (sniff)
    • Phat HS2
      • Apr 2007
      • 14
      Cheers Jas11n... I must admit, i am curious to know what relevance it has for the car...
      What would anyone recommend in getting a spark plug out?? Even though i had it serviced, one the spark plugs would only retract so far... Any suggestions...
      Phat HS2
      :mischeif:
      • Pembo
        • Aug 2004
        • 295
        A decent spark plug socket has a small rubber washer in it which pushes over the ceramic insulator. This then allows you to pull socket up with the plug held in place by the rubber washer.
        Try some blue tack, chewing gum or tap washer. Cut an old rubber floor mat up or just buy a socket with the rubber washer already in it!
        Pembo
        quattro - Original 4WD rallying
        Rally Car photos
        • Jas11n
          • 5067
          Or do you mean one was very tight on the threads coming out?
          Scary when that happens as you don't want to mash the threads. Best way is to untighten a bit, then tighten back down again, repeat very carefully and slowly until it's out. Don't however really force it, a snapped spark plug or a stripped thread is, in most cases, a head off job.
          • Phat HS2
            • Apr 2007
            • 14
            Spark Plug
            Pembo, cheers - but i obviously didn't explain myself correctly...
            The spark plug retracts so far but becomes tight, i don't want to cross thread the head just for the sake of a spark plug... Will try your suggestion Jas11n.... This could be a long time coming out....
            Was in Scarboro over Easter (In laws and garage to service) saw a RS2 Avant Lazer Blue, anyone on here??? Seen it parked outside the Grand hotel... Looked in g.c.
            Phat HS2
            :mischeif:
