Not running on all cylinders.....
  • Knight Rider S4
    • 3541
    have you done a compression test ?...would do this first as you could be spending money for nothing
    you will need one of these
    Have you checked the wiring of the coil going right back maybe earthing which could be causing the problem
    If you think it is the coil swap it over from another and see if problem moves on to another cylinder
    cheers
    93 S2 Avant Parting
    91 URQ RR
    02 A4 tdi Avant
    • mdudziec
      • Mar 2006
      • 44
      Ah, OK, thanks for that Knight Rider. Compression tester sounds good. Now for the embarrasing question...
      ... where do you screw it into to?
      I replaced a coil pack with a new burrel one, which came with a length of cable attached. I noticed that all the wiring on the original coil pack was cracked. So I pulled it all out and replaced with the new cable right back to the POS (yellow) and back to another connector for the Black, where I cut the old cables, leaving just a short tail at the plug, and soldered the new ones onto that.
      I though the coil packs had fixed wiring and didn't think it was possible to swap the coil packs around. Is that right?
      Marv
      • shortsport
        • Dec 2006
        • 186
        The spark plug hole
        • mdudziec
          • Mar 2006
          • 44
          yeh...
          ...of course.
          Thank you
          Marv
          • Knight Rider S4
            • 3541
            LOL.......you take the spark plug out and screw in to there till tight then turn the engine over to get your reading .take the readings of all the cylinders so you can get a good idea of what it should be think it should be around 9-10bar but not sure
            Just checking the coils get back to you
            93 S2 Avant Parting
            91 URQ RR
            02 A4 tdi Avant
            • Knight Rider S4
              • 3541
              Read this thread
              cheers
              93 S2 Avant Parting
              91 URQ RR
              02 A4 tdi Avant
              • mdudziec
                • Mar 2006
                • 44
                Ah, OK.
                So you just turn it over, I don't need to start it, do I?
                Marv
                • aerobreaker
                  • Jan 2007
                  • 47
                  No dont start it, remove all the plugs aswell, and do all the cylinders, you are looking for more than half a bar (pressure difference between the cylinders) if its low on cylinder 2, put a teaspoon of oil into the spark plug hole and redo the test, if the pressure increases then the rings are suspect.
                  • mdudziec
                    • Mar 2006
                    • 44
                    OK, thanks for that guys. Think I'll re-check my soldered coil pack connections and go onto a pressure test.
                    So, I'm looking for between 9 and 10 Bar.
                    Marv
                    • shortsport
                      • Dec 2006
                      • 186
                      Your basically looking for a big differance on no.2 cylinder
                      • Knight Rider S4
                        • 3541
                        93 S2 Avant Parting
                        91 URQ RR
                        02 A4 tdi Avant
                          Also have you checked the coil to spark plug stub leads which are about 6 inches in length. If these are knackered it could cause an issue
                          • Knight Rider S4
                            • 3541
                            Originally posted by mdudziec
                            Ah, OK.
                            If you can start it with the coil cover off it will be a miracle
                            93 S2 Avant Parting
                            91 URQ RR
                            02 A4 tdi Avant
                            • mdudziec
                              • Mar 2006
                              • 44
                              OK great, I'm gonna feel like a proper mechanic with my own pressure testing thingymebob an all!!
                              Thanks for all your help, if you have any other suggestions I'm all ears.
                              Marv
                              • Knight Rider S4
                                • 3541
                                get a multi meter and check there is power going to injecter on cylinder no2 that is the only other thing that we have not covered
                                93 S2 Avant Parting
                                91 URQ RR
                                02 A4 tdi Avant
