Crankshaft lightening
  • terrybullwon
    • Mar 2006
    • 8782
    Any BTDT?
    I was looking at some companies and there prices are not half as bad as what i thought
    I saw Mark H has had is done, the up side is less mass for the engine to spin but the only down side i can envisage is that engine braking is going to be reduced?
    Any thoughts on this?
    Cheers James
    Chef
  • Jay
    • Jul 2004
    • 599
    Becareful where you go for this, I'd seek advice from the obvious e.g Corey, Doug etc, our 5 cyl is hard to do correctly due to the firing order, not the same as doing a regular 4/6/8 cyl. Ask if they have done it before?!
    There are other possible problems/down sides, stalling, rough tickover, gearbox syncros get a harder time, less torque/ acceloration.
    Jay
    • 4WheelDrifter
      • Oct 2004
      • 5773
      • Country: Devon
      Go careful on the lightening, or the balancing man may not have much left to play with.
      I'm not sure about engine braking though. A lower compression ratio should give you less engine braking/less pumping losses IIRC.
      SS
      • SteveH
        • 4460
        Give Phil a call at Bassett down. He can get the crank lightened and then balance the assembly for you.
        Bassett Down Balancing
        Unit 19 Lower Bassett Down Workshops
        Basset Down
        Wroughton
        Swindon
        Wiltshire
        SN4 9QP
        Tel: 01793 812331
        91 Modded 3B
        14 A6 Avant Black Edition
        • Mark Halligan
          • 2001
          Basset Down
          Wroughton
          Swindon
          Wiltshire
          SN4 9QP
          Tel: 01793 812331
          Yep
          he did mine and he knows what he is doing
          Mark - Modded
          • terrybullwon
            • Mar 2006
            • 8782
            Originally posted by Mark Halligan
            Yep
            Thanks Mark,
            Do you find the engine braking is reduced alot?
            Chef
            • Jay
              • Jul 2004
              • 599
              Engine breaking is more a ****ion of the pumping effect of the engine on a closed throttle and is effected more by compression. so lowering the compression ratio will have a bigger effect.
              Jay
              • Mark Halligan
                • 2001
                Originally posted by terrybullwon
                Thanks Mark,
                James
                I haven't noticed any difference in engine braking.
                Mark - Modded
                  Are you going for this James? And did you get a price?
                  • terrybullwon
                    • Mar 2006
                    • 8782
                    I think so Jamo,
                    Price is about for Crank lightening and edging and balance £220, which i thought was quite resonable.
                    But my "list" is getting bigger and the power is creaping up, so i am either going to slow the build down or punish a few cards
                    Chef
                      I know what you mean, I think i'll add it to my big list of things.
                      Was hoping to have the car started this month but may have to delay a while to save up even more
                      • mcandmar
                        • Apr 2004
                        • 5118
                        Are you guys using a lightweight flywheel in conjunction with the lightened crank?
                        Cheers,
                        Mark.
                        91CQ20v - Gone to a new home
                        93UR-S4 - The Magic Carpet
                        94S2Bus - The Emerald Express
                        • aronmatic2
                          • 2129
                          • Country: Hungary
                          has anybody a good answer, why better the light crankshaft?
                          i read a few books about it in motorsport, but nothing any good in serious racecars.
                          Real carbon parts for S2 and RS2. Check Carbondesign on facebook
                            Lighter crank = less intertia = better acceleration
                            • aronmatic2
                              • 2129
                              • Country: Hungary
                              how about the ballance between rods+pistons/crank.(i mean weight difference)
                              the pistons wants to fly up from the cylinder.
                              why has the high rpm race engines very hevy weight crank?
