7a head
  • urquattro-island
    • Mar 2006
    • 1915
    • Home: Norway Current: Iceland
    7a head
    hello I got what looks to be a 7a head today, has anyone here tried this on a turbo engine, just standard??? just wondering?? what could one get?? would it work good at all??
    i will try and take a pic tomorrow so you can see.
    japanischer industriabfall nein danke!!
    www.rackeltrim.se Icelandic Division
  • s2_bo
    • Oct 2005
    • 6067
    iirc it fits straight on but you need to machine a hole for the watter manifold and possibly a Hall Sensor.
    The 7a head should be in a loot better condition that a turbo one with the same millage.
    Im looking to do this very soon too so will keep an eye on your thread.
    Good luck.
    bo
    P.s. is this for your new Shorty project?
    91 S2 coupé - RIP
    98 S8 - Luxury barge
    • merlin's S4
      • Jan 2005
      • 1539
      I'm doing the same. My 7A head is currently at MRC being overhauled and modified to fit my AAN engine. Which reminds me I need to check with Doug to see how that's going!! As Bo said, the head needs the 3 extra holes machining out for the water manifold (7A only has 1 water entrance hole) and if you're converting to ABY/AAN spec then a bracket needs to be made to fit the hall sender. If you're fitting to a 3B engine then this is not required! You can run 7A cams too but you really need to have the car re-mapped to suit. You can fit the standard S2 cams in the 7A head although most people would at least use the 7A exhaust cam as it's a little more aggressive!!
      • aronmatic2
        • 2129
        • Country: Hungary
        i allways use 7a head. you can a find perfect condition piece.
        drill the water manifold holes and thats it.
        Real carbon parts for S2 and RS2. Check Carbondesign on facebook
        • urquattro-island
          • Mar 2006
          • 1915
          Good luck.
          bo
          yes its for the shorty, and i got it for free , the guy did not need it.. ha ha
          • urquattro-island
            • Mar 2006
            • 1915
            I am putting it on a aan engine. what about the hall sensor, what kind of bracket are we talking about any pics
            • s2_bo
              • Oct 2005
              • 6067
              You got some lucking on your side mate!!! They normally fetch over 150 notes with cams here in england.
              Good Luck with the Project..
              91 S2 coupé - RIP
              • urquattro-island
                • Mar 2006
                • 1915
                wow
                well then i really was lucky. thanks.
