Hi guys, I'm from the states and I have an AAN (ABY) converted coupe which is running fine. I decided I needed more power, so I purchased an RS2 exhaust manifold and a Garrett GT2871 turbo. After initial fitting, the turbo hot-side hits on my passenger (right-side) frame rail and the frame rail will have to be cut. Has anybody who has done a similar upgrade ran into this problem? Cutting the frame rail is not a problem, I'm just suprised that there isn't enough room. Thanks for any info you can provide.
Fitting a GT2871 turbo in a coupe
Never had an issue to be honest, we always ensure the engine mounts are new and raise the engine slightly to ensure there is clearance (even after the engine mount has sagged/failed). For a more permanent solution is to use uprated engine mounts (034 motorsport spec etc.)
You certainly don't need to be as extreme as cutting your chassis leg.Corey
01636 822288 -
i never seen like this. i have gt30r and i havent cut that place.
maybe you turnerd your turbo upside down.
(sorry, joke)
Real carbon parts for S2 and RS2. Check Carbondesign on facebookComment
As Corey said, replace the engine mounts! I thought mine were alright but there was a good 1/2" raise when they were done. Enough to put the 3071R hotside clear of the chassis except for hard cornering (when there was a little knocking).
As Corey also said, spacers between the mount and the arm will do the trick. This is what was recommended to me by a few others that have had the same problem. A few large washers did the trick!
rossAUDI - saving Dad's from minivans since 1994
I've seen this Coupe in person and any amount of spacers wouldn't work. The engine mounts are new as well.Joe "NoNonsense"
axis motorsport
joe@axismotorsport.com
"At the end of the game, the king and the pawn go back in the same box."Comment
? i guess cutting would be the only way then... didn't realise there was any difference in the body. Any pics that show a bit more of the engine bay for comparison?
Here's a linky to my 3071 'contact' area, you'll see why the advice here was to use spacers:
Hotside ContactAUDI - saving Dad's from minivans since 1994
