Overboost protection checklist
  • VladaS2
    • Aug 2006
    • 185
    • Country: Yugoslavia
    Is there a definite list of things to check when someones gets overboost protection. I have diagnosed that by ECU fault code and also by usual symptom of cutting the fuel supply when maximum boost should come.
    So far we have checked for boost leaks, swapped MAF, N75 and spark plugs, and whole ECU with MAP sensor and nothing. What else is there to be checked?
    My Online Blog
  • WabTheKing
    • May 2004
    • 2567
    intake air temp sensor upset mine, they are expensive tho so be better to be sure first, have you vag com'd it?
      Clean the MAF connector?
      • VladaS2
        • Aug 2006
        • 185
        Yesterday we checked (swapped) TDC sensor, knock sensors, coil, APS sensor, TPS sensor with the same result - the car still hesitates and jerks after 3000 rpm on WOT. VAG COM does not show anything. Any more ideas?
        My Online Blog
        • andyg plym
          • Nov 2006
          • 4646
          re
          you havent got a bleed valve on there have you?
          • VladaS2
            • Aug 2006
            • 185
            I am not sure what you mean Andy?
            Checked WG diaphragm, replaced TBV still nothing.
            My Online Blog
            • Ouarese
              • Dec 2006
              • 8
              • Country: France
              Check fuel vapors recirculation valve, mine is broken, an air flux enter in admission manifold and the symptoms are the same than yours.
              • andyg plym
                • Nov 2006
                • 4646
                re
                bleed valve as in a manual boost controller. used to have one and it made the fuel cut off come in all the time
                • VladaS2
                  • Aug 2006
                  • 185
                  No bleed valve.. As for fuel I have 044 bosch fuel pump and it recircs 2l of fuel in minute.
                  My Online Blog
                  • WabTheKing
                    • May 2004
                    • 2567
                    try new spark plugs, i had a miss fire / hesitation from bad spark plugs
                    • A80Avant
                      • Sep 2005
                      • 10873
                      • Country: Greece
                      also try new spark plg pipes as well
