I have a running fault on my urS6.
All appears to be fine until i floor it normally in a high gear with revs above say 4500rpm the car starts to hesitate, i back of the gas slightly it runs fine again.
The car has been chipped by MRC I'm lead to believe,has a 3bar map sensor and a replacement coil pack from 034. its just been serviced by Pete Barry at white cottage quattros and he said that there is no boost leaks and he believes the problem may be the mapping may need adjusting?
I also run the car on 95 ROn, should i or 98 RON.
Any thoughts would be most appreciated.
Thanks
Tom
Thanks
Tom
and you should notice a difference.
