Getting rid of aux radiator
  • Matt_D
    • Dec 2004
    • 515
    I know a few have done this when fitting bigger intercoolers and oil coolers in its place.
    I would like to use a 180 degree silicone hose to block this up rather than bungs as some have, all i would like to know is what bore size should i get to match the standard rubber hoses ?
    Cheers me dears
    '95 ABY Avant - Sold
    '98 B5 S4 -MRC400+ = 464ps 741nm
    18-20mm will do the job or a standard dump valve blanking plug.
    I hope you dont mean a hose joined from top to bottom of the rad?
    Big no no as it allows a bypass of hot coolant across the rad!
    • A80Avant
      • Sep 2005
      • 10873
      • Country: Greece
      nice cold weather nagates this aux rad.but here in Greece all rads are needed....and bigger intercoolers!!! grrrr no way to fit everything!
      • dan_b
        • Sep 2003
        • 3670
        Cheers me dears
        In a word, no. You'll effectively be by-passing the main coolilng circuit if you do this, which will kill your car faster than death by lethal injection. What you need to do is bung the pipes...
        • Matt_D
          • Dec 2004
          • 515
          Ahh ok i thought that if i just join the two pipes up it would be ok.
          • s2driveruk
            • 12696
            could just buy a 7a hose and a £2.50 brass radiator bung and tada job done.
            1992 3b S2 Coupe
            • s2 on the way
              • Jul 2004
              • 220
              so this is bad then?????
              I haven't started it yet, but am close...thought this was fine, but as I am reading, it doesn't sound verygood...
              • s2driveruk
                • 12696
                noooooooooo dont do that for the reasons mentioned above
                1992 3b S2 Coupe
                • Al Wyn
                  • Nov 2006
                  • 3746
                  Bad boy.. naughty boy.. straight to bed not a good idea at all !
                  S2 + RS2 yep ive had a few love em... Laser red S2 avant... Brilliant black lhd RS2... Polar silver RS2... RS blau RS2... CheeRS Al
                  • s2 on the way
                    • Jul 2004
                    • 220
                    mannnn,
                    I thought it was such a good idea too....
                    so I just plug off the top opening or the bottom to make use of the radiator...
                    cuz before I had it just plumbed to the top and thought the coolant would just flow through the endtank without going to the radiator, so I t'd off that to the bottom..
                    so i'm assuming I need to plug off the top right?
                    • Flat on my back
                      • Jan 2007
                      • 2449
                      Simple really.
                      The 2 ends that used to go to the aux. rad., cut them shorter (one from the top of the rad. pointing ta front of car, t'other smaller bore from the bottom rad. hose)and plug BOTH ENDS with copper pipe ends stops and jubilee clips from yer local diy shop. Job done!
                      Carlos.
                      • Flat on my back
                        • Jan 2007
                        • 2449
                        Found this, shows the 2 pipes.
                        7A aux. rad.
                        Carlos.
                        • s2 on the way
                          • Jul 2004
                          • 220
                          got ya....
                          so cappin the top port I set to do.......
                          thanks.
                            Thanks for the reminder, I have one of those 7A hoses I'm going to sell at somr point.
