What a PITA this has turned out to be, the thing i was dreading happening has happened :mad:
2 studs sheared off in the head, took me about 12 hours to remove the thing, the last bolt (the one in the middle of bottom row, hardest to get at) was so rusty it was completely round, had to gring it away with B&Q's answer to a dremmel and a mirror coz you cant even see it, eventually with the help of a crowbar it came off,
Dont know how im going to remove the broken studs, they're arrowed in the pic, i'll need the worlds smallest drill to get to them
have about 8 inches of room
any ideas? dont fancy removing the head again:mad:
, there is a bit more room but not enough to get a standard sized drill in, thought about undoing engine/snub mount, worth a try.
If you are desperate and want these asap PM me and we'll see if Steve can gt another set for me.
