Ross Racing Pistons
JE pistons
Mahle Pistons
What others?
I am tempted to go with standard Mahle pistons(they are standard ones?) - although I need 81.5mm diameter because of reboring. I will get the raised part machined off so the piston will be flat, apart from the valve recesses. These will cost me £112+vat each, but they come with oversized rings and pins.
Anyone know where I can get these cheaper?
JE pistons
Mahle Pistons
What others?
And post a picture.
, just had a look at their site in the FAQ section and they say to just tell them what size bore you have and they make them to fit.
