In fact, NM is not a crap, but it develops too low torque at the bottom, so some day I'll swap a 3B in my coupe or prepare my NM for low boost
Porkkis would you be so kind and explain the differences in 3B engines a little bit more detailed ?
Are you able to describe differences in ECU software for both cars ? I'm using stock 200 soft in my b2q currently, so I need to know what would be the difference comapring to stock S2 software. For now I don't want to remap of the ECU because I don't know how much torque the 90quattro gearbox is able to handle.
-Flywheel: is the wheel lightened in S2 comparing to 3B200 ? What is the difference ?
-Breather ??
-Oil pan if S2 with A/C: I heard that 3B has weak oil pans, is it true ? Should I upgrade it ?
-Breather ??
