Further developments...
Car now has 5 correct Bosch plugs. Still misfiring though.
Discovered that the problem is with the first cylinder - closest to the front of the car. Worked this out by disconecting each of the injectors one at a time.
Then looked at the coil for this cylinder and discovered that plastic has melted out of the coil
Not sure why I didnt see it before.
I was wondering what might have caused this
I dont want to put a new coil in only to have it get damaged again. As previously mentioned, I have tightened the plugs before the problems began. Could it be that some exposed wire has shorted the coil and damaged it ? Also I assume the fuse I blew was as a result of this coil, but hoped someone could tell me what fuse it is in the picture in my last post.
Thanks guys.
I dont want to put a new coil in only to have it get damaged again. As previously mentioned, I have tightened the plugs before the problems began. Could it be that some exposed wire has shorted the coil and damaged it ? Also I assume the fuse I blew was as a result of this coil, but hoped someone could tell me what fuse it is in the picture in my last post.Thanks guys.
) and knackered coil packs. Did you see a big performance improvement on replacement.
Looks good though doesn't it
