Differance between G12 and other collants
  • 220bhp
    • 2578
    • Home: United Kingdom
    Whats the differance between G12 and other collants ,apart from the price
  • Audi Parts Guru
    • 1317
    G12+ can be used with both the old (blue) and new (pink) Audi/VW coolants. It is the only one that you can get from your local Audi/VW stealer now, and It's the only one I would use
    Part number G012A8FM1 £6.55 inc vat from your local stealer
    S2 Avant......fully loaded :rock: :bow: Slipper Wagons Rule !!!!!
    • CoupeWannabeS2
      • 403
      You can get the G12 + from German Swedish car parts, there is one in Ipswich and they sell it for £5.82 a bottle (1.5 litres per bottle). Also if you tell them your an S2Froum member they will knock 10% off that price
      • 220bhp
        • 2578
        • urquattro-island
          • Mar 2006
          • 1915
          • Home: Norway Current: Iceland
          g12
          the g12plus can be mixed with any other coolants, and it is best coolant for the new alloy engines from VAG
          japanischer industriabfall nein danke!!
          www.rackeltrim.se Icelandic Division
          • Jonas_R
            • 3780
            • Country: Denmark
            Does the bottle come mixed or do you mix it a ratio of 1:1 G12+emintralized water?
            Just wandering since iam going to change my coolant soon.
            Sleeper S2 Avant +450
            A6 Avant 2.7t Stage 3
            Audi S2 Coupe RS2'ed
              It needs to be mixed with water. On the back it tells you how it can be mixed 1:1 2:3 or 3:2 depending on your local temps.
