I need help identifying a turbo I bought a few years back, and your thoughts on whether it makes sense to install in my car.
The turbo has a K26 compressor housing part no. 5236 970 6411. The center section has the following numbers on it (though not 100% sure) 552-?-2699 and 035149585A.
The compressor wheel is as follows:
16 blades
exducer .75
inducer .51
compressor outlet is .45
compressor inlet is .53
exhaust outlet is .61
exhaust inlet is .61
I was told that the compressor wheel is off a k27, but I don't know if it's true.
I have a K26 in my car and have been considering replacing it with this one. The k26 that I have in my car has a much smaller hot side. I believe the compressor housings are the same, but the compressor wheel on the one I have in my car does not have as many blades.
The inlet of the exhaust was worked on to smooth out the lip into the turbo, which I hope does not affect the integrity of the turbo.
While I would like to replace my k26 with this other turbo, I don't want to end up with more lag than what I now have.
Can anyone tell me if the compressor wheel is off a k27? If it is off a k27, what kind of performance can I expect given the fact that it has a k26 compressor housing? Lastly, what are your thoughts on installing this turbo on my car to replace the k26 that I have (which is the smaller version of the k26s)? Thanks...
16 blades
exducer .75
inducer .51
