Hello everybody.
after spending a lot of time searching for the problem with my S2 (93 ABY),i think that i have found it,, as often it's something pretty simpel
but becouse of the strange faults that where occuring(no spark or signal to the injector's)it took me quite some hours.
I found out that there was no scope signal from the reference sensor(62 degrees before tdp)mounted on the crank case next to the engine rotation sensor
after taking a look at the flywheel of a UrS6 i saw that it had a small metal square notch point welded to it (so it seems)witch was missing on my flywheel!!
Through this forum i found someone who has a dual mass flywheel for me
,but i want to be sure that the metal notch is atached to the flywheel and not something else,can anybody confirm that? and if possible with a picture of the flywheel with the metal notch on it?? and is there any difference in flywheels for ABY from 93 up to 96?
jeroen.
but becouse of the strange faults that where occuring(no spark or signal to the injector's)it took me quite some hours.I found out that there was no scope signal from the reference sensor(62 degrees before tdp)mounted on the crank case next to the engine rotation sensor
jeroen.
(it's been standing still for months now).
