Hello all. I have a non-Audi problem that I hope someone here could help me with.
A friend of mine has a 1997 Lotus esprit V8tt that I have been working on. The vehicle is only driven on weekends at track events. When the car is cornering at hi speeds, the vehicle stumbles. This happens on either left or right turns. Fuel pressure is steady at 60psi and anything else that you can think of has been checked. New plugs, coils, coil wires, injectors... have been installed prior to my seeing the vehicle.All the usual suspects have been checked. There is no problem with the vehicle running in a straight line. I have been looking at some software to read live data from this place http://www.lotusespritworld.com/EGui...ance/OBII.html
Does anyone here have any experience with this software?
Thanks, Chris
Thanks, Chris
We have tried all of the above suggestions, changing out fuel pumps, bypassing the inertia switch, filling it completely with fuel, monitering fuel pressure, disconnecting the evaporative emissions charcoal canister.... still has same problem. The only way to duplicate the
I was hoping for another answer. Thanks anyway.
