piston rings
  • valjo
    • 1110
    • Country: Latvia
    piston rings
    hi!
    i need to change piston rings in my aby engine. i wonder if anyone know, if 3B and ABY engine has the same rings?
    In catalog i found only rings for 3b engine, but i wonder ABY has the same?!
    thanks for help!!!
    Audi Coupe S2 1993
    Audi V8 4.2 1993
    Audi cabrio 1998
  • Audi Parts Guru
    • 1317
    Yes they are the same.......
    You will need 5 x 026 198 151A
    • valjo
      • 1110
      • Country: Latvia
      thaks!!!
      i will buy aftermarket piston rings...... what should i remake in my engine when it is totally restored?
      Audi Coupe S2 1993
      Audi V8 4.2 1993
      Audi cabrio 1998
      • Doug_RS2
        • 3847
        Valjo
        Do you realise that the block will have to come out - even if the only thing you are changing is rings?
        While you are doing that, there are a lot of things that have to be replaced, bolts/gaskets.
        Ehn the head is off it should be leak tested and skimmed.
        You might discover the reason for worn rings is actually damaged bores so a rebore might be needed - that is big money as you need new pistons, might as well put uprated rods in. Balance the crank.
        This could end up being a huge job - this is what has happened to me - and the car will be off the road for another 6 weeks.
        • valjo
          • 1110
          • Country: Latvia
          dough: engine head is allready restored, and is like new. i hope that my pistons are ok. New one are pretty expencive (kobleschmitz set 1300eu ops: ).
          the car goes ok, it pull like rocket, the problem is only white smoke, and oil consumation, it needs about 0,5l/1000km
          Audi Coupe S2 1993
          Audi V8 4.2 1993
          Audi cabrio 1998
          • Doug_RS2
            • 3847
            If it is just the smoke , it could well be the turbo or valve stem oil seals. valve stem oil seakls can be changed without taking the head off if you have the correct tools.
            Check the compression of each cylinder first specs are:
            9 Bar to 13 Bar
            Worn is 7 Bar
            Max limit between cylinders is 3 Bar.
            If there are any low cylinders - you can test the rings by putting a small amount of clean engine oil in the top of each cylinder - redo the compression test and if the low cylinders match the others then that shows you have worn piston rings.
            HTH
            • valjo
              • 1110
              • Country: Latvia
              doug_rs2; i have yust change valve steams in engine head. so my head is ok. It could be turbo or piston rings. I will try your test with compression.....
              do u have any idea how can i check turbo for oil leaks?
              regards grega
              Audi Coupe S2 1993
              Audi V8 4.2 1993
              Audi cabrio 1998
              • Habib
                • 316
                • Home: United Kingdom Current: Italy
                I had blue smoke coming out the back that was due to a broken crankcase breather pipe
                • Doug_RS2
                  • 3847
                  Leave it idling for 5 minutes, then give it a hard rev - if you get lots of smoke it is likely to be the turbo - how many miles has the turbo done?
                  • valjo
                    • 1110
                    • Country: Latvia
                    my car has about 60k miles. i will try doing the test you tell me to do!!
                    i will tell you results latter
                    thanks!
                    Audi Coupe S2 1993
                    Audi V8 4.2 1993
                    Audi cabrio 1998
                    • Stick Insect
                      • Dec 2003
                      • 2338
                      Check for oil in the inlet pipework, this is ususally a good sign. This was the case for the Metro Turbo. I don't know about the Audi.
                      David.
