i need to change piston rings in my aby engine. i wonder if anyone know, if 3B and ABY engine has the same rings?
In catalog i found only rings for 3b engine, but i wonder ABY has the same?!
thanks for help!!!
Audi Coupe S2 1993
Audi V8 4.2 1993
Audi cabrio 1998
Do you realise that the block will have to come out - even if the only thing you are changing is rings?
While you are doing that, there are a lot of things that have to be replaced, bolts/gaskets.
Ehn the head is off it should be leak tested and skimmed.
You might discover the reason for worn rings is actually damaged bores so a rebore might be needed - that is big money as you need new pistons, might as well put uprated rods in. Balance the crank.
This could end up being a huge job - this is what has happened to me - and the car will be off the road for another 6 weeks.
dough: engine head is allready restored, and is like new. i hope that my pistons are ok. New one are pretty expencive (kobleschmitz set 1300eu ops: ).
the car goes ok, it pull like rocket, the problem is only white smoke, and oil consumation, it needs about 0,5l/1000km
Audi Coupe S2 1993
Audi V8 4.2 1993
Audi cabrio 1998
If it is just the smoke , it could well be the turbo or valve stem oil seals. valve stem oil seakls can be changed without taking the head off if you have the correct tools.
Check the compression of each cylinder first specs are:
9 Bar to 13 Bar
Worn is 7 Bar
Max limit between cylinders is 3 Bar.
If there are any low cylinders - you can test the rings by putting a small amount of clean engine oil in the top of each cylinder - redo the compression test and if the low cylinders match the others then that shows you have worn piston rings.
doug_rs2; i have yust change valve steams in engine head. so my head is ok. It could be turbo or piston rings. I will try your test with compression.....
do u have any idea how can i check turbo for oil leaks?
regards grega
Audi Coupe S2 1993
Audi V8 4.2 1993
Audi cabrio 1998
