Hi,
I am going to follow the RS2 turbo-way on my ABY and just bought a VMAP 3 bar sensor (plus a lot more stuff off course).
So I will be loading MTM RS2 software into my ABY ECU.
On the German Meckis forum I read that if I would replace my Bosch 250Kpa sensor with a Bosch 300Kpa version I would need to change the R201 resistor into a 5k62 Ohm resistor inside the ECU. This would be needed to 'tell' the ABY ECU (same for AAN) that I am also are using bigger RS2 injectors as the standard ABY ones.
Now I do not know if this is also neccesary for the VMAP sensor?
Is the R201 resistor linked to the RS2 injectors or to the Bosch 300 Kpa sensor?
