Whats the difference with the engine mounts
  • Graham
    • 1622
    I have just recieved my new engine and gearbox mounts, the engine mounts have different part numbers and prices but as far as i can tell they are both exactly the same. So what is the difference between 8A0 199 382 and 8A0 199 382 D.
    I dont want to get them the wrong way round
    According to the good book.
    8A0 199 382 D is the right hand mounting ( turbo side )
    8A0 199 382 is the left hand side mounting
    Graham register to www.vagcat.com I think you'll find it handy.
    • mcandmar
      • Apr 2004
      • 5118
      I think there was also a different right hand side mount for AC cars. And some also had a little rubber piece on top which i assume was to protect against heat.
      91CQ20v - Gone to a new home
      93UR-S4 - The Magic Carpet
      94S2Bus - The Emerald Express
        Graham has bought the AC mounts mcandmar.
        The cap your referring to is part number 443199469C for the right side. There isn't one for the left hand side ( passenger )
        • Corey
          Banned
          • Sep 2003
          • 2793
          8A0 represents the ABY and uses the offset mounts.
          On the 3B you can use 1 mount for both sides, ABY is unique each side.
          8A0 199 382 C is the right for non AC
          8A0 199 382 D is the right for AC
          8A0 199 381 is the left non AC
          8A0 199 382 is the left AC
          The 3 white dots indicate the suffix number Graham, yours having 3 white dots shows it as a suffix D, giving you 2 right side AC mounts.
          Corey
          01636 822288
          • mcandmar
            • Apr 2004
            • 5118
            Corey what exactly is different with the ABY mount? To be more specific to put an ABY w/6speed into a CQ which mounts do i need.
            Cheers, Mark.
              Ah good to know about the dots!
              • Corey
                Banned
                • Sep 2003
                • 2793
                Cheers, Mark.
                The ABY mounts are offset. On the CQ you will need to use the 3B style engine mounts in either SD,TD or MS variety of course
                Corey
                01636 822288
                • mcandmar
                  • Apr 2004
                  • 5118
                  What i really mean is offset which way, slightly forwards, backwards, to the left or right? Curious as to why it has moved, is the difference in the alloy supports or have they moved the engine position slighty for some reason?
                  I thinks i'll be going for the SD versions anyway
                    on the subject of engine mounts, how do you tell when they are knaceked?
                    My car has a little wobble on idle, i can only assume its the engine rocking on its mounts?
                    • Graham
                      • 1622
                      So if both mine are the D model, can they be used on both sides, as i ordered one for either side. Or am i screwed with 2 same side mounts?.
                      If i fit them would there be a problem or are both uprated just to withstand heat?
                      • Graham
                        • 1622
                        How i found them to be knackered was when the engine tried to take off out of the front of the car leaving a nice big crescent moon in the back of the intercooler
                          ouch
                          • pixsaudisex2
                            • Sep 2004
                            • 3110
                            i had a problem when i ordered mine two of the same came ... it took me ages to see that the two i took of looked different to each other. only slightly different ..so the one mount fitted and the other didnt ( the one that didnt fit was bust as luck would have it) so in the end i couldnt be bothered ordering another so i made the mounting holes on the one mount a bit bigger only slightly and well the mount fitted on and as far as i can tell one year later it has not made any difference to where the engine sits .. i know scary ... an it always makes me sad when i do something like this. it was on an aby.. just thought id share this tail... il put anothe rpost up when it brakes...
