Brief run down of the problem.
Traveling to VWFestival Sunday morning, fine all the way then 2 miles from the show I pulled out of a junction (not ragging it either) and at it dropped onto four cylinders. No warning, no misfire etc, just a snap drop onto four.
Both POS's are fine and were brand new in Feb, but I've bought another and it works fine, powering cylinders 1,2 and 3 ok. Switching existing POS's around makes no difference, still nothing on cylinder four.
Coilpack four was new in feb too (in fact all five replaced), but I've replaced it again and still a no show of a spark. Replaced the spark plug (which was new 2 months ago), still no spark.
Injector four is pulsing, confirmed via being able to feel the "ticking" with your hand, and also via vag-com code check and output check. Injector four now also conformed to be delivering fuel.
Wiring between coilpack and POS connector ok (to rule out a dodgy connector), wiring between POS and pin 20 of the ABY's ECU connector is ok too.
So that leaves the ECU.
I've had an offer from forum user of another immo ECU from an ABY.
Mines an immobilsed ECU too. I take it the one I'll buy will switch in and run ok?? no problems with immo's being all pedantic about it?
Thanks in advance.
Jas..
Thanks in advance.
Jas..
