The problem with my s2 3b mtm chipped is, when i'm driving at normal speed on the motorway sometimes suddenly the boost is falling off to .5bar mechanical boost.
It only happend on the motorway driving the same speed
Last time i noticed a slight hesitation, like a pre warning.
When i turn off the ignition and restart the engine, the boost is back.
I changed
Knock sensors
Lambda
WGFV
DV
Cleaned the maf
no boost leaks
vacuum lines
Any ideas?
I changed
Knock sensors
Lambda
WGFV
DV
Cleaned the maf
no boost leaks
vacuum lines
Any ideas?
