Hello
I have a serious problem with my rs2 -94. At idling and low rpm the car goes and sounds like a V8. It is confirmed that a lot of unburned fuel goes trouhg the engine at idle and low rpm but when the boost comes up it runs as it should and max boost is 1.4 bar. In the morning the car runs very nice the first 1.5 minutes and then it starts vrom vrom vrom idling speed 750 ->850 up and down. When I come to the redlights and push the clutch in it goes very nice down to idling speed.
Following things has been tested or tried from a another rs2:
- air mass meter
- new spark plugs
- all new ignition coils
- new ignition amplifiers (POS)
- pressurized the intake system, could not hear any leakages
- changed all small vacum hoses
- cambelt is right
- another ISV
- no fault codes
- engine doesn't use any oil
- no black or white smoke
- fuel pressure is ok
- injection nozzles pressurized and tested, also tried to take one connection off at nozzle but its the same on all cylinders.
- magnetic (n75) valve tested
- compression ratio is ok
- cylinder head is leaktested and ok
- air temp engine inlet ok according to vag-com
- engine temp ok acc. to vag-com
- new lambda
- no leakage in crankcase breathing hoses
- at idle there is only -0.2 bar vacum in the intake manifold and when I blip the throttle it goes to -0.5 bar as it should be. Flat out 1.4 bar
MOT emission test
idling speed
CO: 1
CO2: 11.2
HC:1440
O2: 5.5
Lambda: 1.00
3000 rpm
CO: 0.99
CO2: 14.5
HC: 91
O2: 0.24
Lambda: 0.98
Is it possible that the inlet camshaft could be 1 teeth wrong?
Please I need help !!!
- air mass meter
- new spark plugs
- cambelt is right
- another ISV
- no fault codes
- new lambda
MOT emission test
idling speed
CO: 1
CO2: 11.2
HC:1440
O2: 5.5
Lambda: 1.00
3000 rpm
CO: 0.99
CO2: 14.5
HC: 91
O2: 0.24
Lambda: 0.98
