To be honest the diff lock pipe is not attatched as I don't ever envisage using it. so it is all in the engine bay. Am having a good run over all the pipes on Wed but if anyone local has a Pressure test kit I could borrow for a few days that would be great. Just to double check everything.
Dark Grey Avant
RS2 FARB
Alloy Subframe Bushes
Right pressure tested just now and the system held no pressure at all. Plugged teh exhaust and tried again. I am testing the whole system to find a leak, no luck again so got the water and washing up liquid mix out and sprayyed round a bit....
Still no luck.
Gave up for the day put it all back together and then started the car.....
Then saw a pool of water dissapear and the engine ran bad......
Bleeding manifold has cracked!!!!
So got to strip the car down again now to gte it off.
BUM!!!
Dark Grey Avant
RS2 FARB
