Hi Guys,
Just making sure I have everything correct before I commit to finishing my 1.8T conversion loom. Looking at URS4boy`s excellent guide the pinouts for the brown 4 pin POS connector (N122) are as follows:-
1 - Cyl 3
2 - POS ground
3 - Cyl 2
4 - Cyl 1
But looking at the ABY motronic manual and the Motronic pinout guide on S2 central I get...
1 - Motronic connector 23 (S2Central says this pin is Cyl 1)
2 - POS Ground
3 - Motronic connector 2 (S2Central says this pin is Cyl 2)
4- Motronic connector 1 (S2Central says this pin is Cyl 3)
So the 2 sources give Cyl 1 & 3 in reverse. Which is correct? I know that the conversion guide is for the URS4, but is the S2 the same?
My Wire Colours into the 4 pin POS connectors are as follows (which is different from the guide)
N122 (Brown)
1- Black/Blue
2 - Brown/Red
3 - Purple
4 - Green/White
N127 (Black)
1 - Not wired
2- Brown/Red
3- Green
4 - Black/Red
So do I trust the guide, or do I need to swap Cyl 1 & 3?
Ed
1 - Cyl 3
2 - POS ground
3 - Cyl 2
4 - Cyl 1
2 - POS Ground
N122 (Brown)
1- Black/Blue
2 - Brown/Red
3 - Purple
4 - Green/White
N127 (Black)
1 - Not wired
2- Brown/Red
3- Green
4 - Black/Red
Ed
