Mis-fire causing boost cut
  • kwlw
    • Sep 2004
    • 1025
    • Country: Lithuania
    Originally posted by Bjoern
    I will try to go on 92 octane fuel next time. If it helps, then I know where the problem comes from.
    Be carefull with the boost and 92. Especially when you suspect knock sensors not working properly. The results can be demolishing.
    Sau
    • Bjoern
      • Jan 2006
      • 35
      • Country: Denmark
      Thak's for the warning. I'm disconneted the knocksensors and go for a ride. The car go wery bad. Then i reconnect them and get som 92 octane. Now i have go 200 km. without problems.
      The car is a bit slow, but it drive smooth and without cut the problem.
        MAF - I had months of this pain on mine - it would be fine some days, then rubbish on others... Seemed to be worse at high temps. No fault codes ever... Changed the MAF to a spare and its like a different car.
        At high temps I know my original coils and HT stubs (ABY) are causing a lil grief with misfires but I don't get the cutouts anymore.
        Borrow a spare MAF or airbox if you can - the MAF is an expensive booger to change on a whim. Oh and be sure to reset the ECU first - just in case its running a funky/safety map cos of bad values from the MAF.
        Paul
