Mis-fire causing boost cut
  • Chris M
    • Sep 2003
    • 1030
    Having a problem with my 91 S2 3B.
    I'm trying to find what enables boost cut other than the ECU, brief story:
    Driving along -all fine. Floor it, boost zips upto 1.7 bar then slight misfire, back off and change gear, back on full throttle, boost is now pegged at 1-1.1bar. Quick flick of the ignition off then back on and back to 1.7bar. No faults thrown on VAG-COM either
    The car had a slight misfire before but no boost cut.
    Anyone had this problem, maybe the coil?
    Cheers,
    Chris
    Cheers,
    Chris
    Silver S2 Avant : Sold
  • CliveH
    • Jun 2005
    • 1319
    No one...???
    Past: S2 ABY coupe RS2 spec with lots of mods, S4 B5 saloon, RS6 C5 saloon, S8 D2 FL, RS4 B7 saloon, S4 B6 avant
    Present: S4 B8 avant, MRC Stage 2
    • spink
      • 4382
      Ive got a couple of coils spare if you wanted to try one?
      • 220bhp
        • 2578
        • Home: United Kingdom
        3b at 1.7bar, I wish I had your problem,strugle to get 0.8 out of my 3b.If you realy are seeing 1.7bar then I can only think its over boost protection coming in
        • valjo
          • 1110
          • Country: Latvia
          could be MAF
          Audi Coupe S2 1993
          Audi V8 4.2 1993
          Audi cabrio 1998
          • Chris M
            • Sep 2003
            • 1030
            Its RS2 spec I think it could be the knock map reducing boost when it misses. Just fitted new knock sensors. MAF has been cleaned.
            Cheers,
            Cheers,
            Chris
            • T2Andy
              • 1903
              Chris had the same prob this week ,floor it and nothing much happened felt like the power was holding back alot ,then it would surge upto full boost and then cut for a split second.so i cleaned out the miltec DV ,the piston seemed to be sticking cleaned the maf
              multiplug and put the standard air filter back in and all is well ,i was seeing about 18\20psi.it shat all over carrado earlier anyway.
              • zlobo
                • 967
                do you run on orig sparkplugs?
                ABT C5 Lord Of The Rings
                2004 1/4 Mile ET 12.00 191Km/h @1,5Bar
                2009 1/4 Mile ET 11.92 213Km/h @ 1,5Bar 437WHp
                2010 1/4 Mile ET 11.45 110Km/h @ 1,5Bar 437Whp
                kostic.nu
                • Chris M
                  • Sep 2003
                  • 1030
                  Tried F5DPOR's and also some NGK plugs.
                  Cheers,
                  Chris
                  • Ross
                    • Aug 2005
                    • 3399
                    ..and still no joy mate?
                    • spink
                      • 4382
                      Cris,did you get/try that coil yet?
                      • Chris M
                        • Sep 2003
                        • 1030
                        Yeah thanks , think the coil has cured the mis-fire, still cuts boost after a WOT blat tho
                        Cheers,
                        Chris
                        • CliveH
                          • Jun 2005
                          • 1319
                          Bummer!
                          • Chris5044
                            • Feb 2005
                            • 1663
                            anyone else any ideas?
                            • Bjoern
                              • Jan 2006
                              • 35
                              • Country: Denmark
                              Hey Chris.
                              Mine S2 does the same. It's an original ABY '94. It can go smoothly for a couple of days, then it begin to jerk a little, and on the next hard acceleration it cut the fuel. After that it can max. Press 0,4 bar.
                              I have a mate, his S2 do exactly the same. He has shifted almost everything electrical, pressure hose and vacuum hose.
                              I mistake the knock sensors. It is practically the only thing he not has shifted.
                              I will shift mine a.s.a.p.
                              It’s a very strange problem. Nobody seems to have the right solution. Somebody say it’s a leak in a boost hose, and other say it’s an over boost projection. When I’m think back, I have notice that the problem gets bigger when I drive on 98 octane fuel. That’s why I think it’s a knock sensor problem. I will try to go on 92 octane fuel next time. If it helps, then I know where the problem comes from.
                              Bjørn, DK.
