what can cause this problem that appeared on me today?
I recently replaced a MAF that had bad idle problems with a previous one that worked fine except the high rev range(measured on the remap while in germany and it was suggested to me to replace it).
What should i check? VAG COM turned out only fault code 561 intermittent telling me to look out for fuel regulation and possible G70 check(MAF).
Fuel problems could only be of bad fuel filter,although it is a year old but i have my doubts,since the fuel pump is sounding a bit louder than what it did back in Germany.
MAF again???
What could cause so frequent MAF problems except being a bad sensor itself?The thread is there,hasnt been sucked out in any of the mafs i have tried on,but still i cannot understand it!
Can this also be an O2 sensor fault?
thanks
Vasilis
MAF again???
thanks
Vasilis
