For some people that dont want to go to aftermarket ECU that enable to lose the MAF i have discovered that the MAF is in more danger than the OEM cars that havent been tampered with.
my setup is like this:
Although the MAF is on the original position,it seems that the heat generated from the whole area is very intence and so this in addition to the fact that the maf is very near the turbo,i think may have something to do with MAFs getting destroyed much sooner.
My thought is to remove the RS2 airbox cap only,move the maf furhter back,get some 80mm samco hose 180degree curve as well and a KN filter cone,and use the base of the airbox to fit everything inside.Then build a cap with heat protection to cover both the filter cone as well as the MAF.
Do you think this would be a better solution?
any other suggestions???
I know the RS2 airbox is very very good,but i must do something about the heat and turbulance destroying my maf...
, even seeing car live. Seems that it's #2 question after seeing WG cap nipple
. It just optical ilusion. Actualy one of the hoses go to the intake rubboer boot. I have only one hole i it, that's why breather and DV output come to one place, then to the intake.
