When coming off throttle I notice a chatter noise. It sounds like a much quieter version of a group B rally car.
Is this wastegate chatter or is it turbo stall?
It has the OME recirc valve on it, could it be the noise from this or if this isn't opening could it be causing the turbo or wastegate to make this noise?
UrS6 - Homefry, Bailey DV, PiperX filter, Samco hoses, H&R springs, 3" D/P back zorst, 270bhp and 260ftlb :rock:
Dump valve. Mine sounded like an S1 at Combe when I came off the track! Loved it but it's not too good for the car so best to change it. Bosch 710N (Audi S3) one is more modern than the OEM S2 and a lot of people run them (including me). Should be less than £25 from VAG Parts. Or you can buy a leaking Forge one and get a sarcastic letter when you send it back for £80... the choice is yours!
