Wastegate chatter?
  • Animal Mother
    • Jul 2007
    • 1135
    Wastegate chatter?
    When coming off throttle I notice a chatter noise. It sounds like a much quieter version of a group B rally car.
    Is this wastegate chatter or is it turbo stall?
    It has the OME recirc valve on it, could it be the noise from this or if this isn't opening could it be causing the turbo or wastegate to make this noise?
    UrS6 - Homefry, Bailey DV, PiperX filter, Samco hoses, H&R springs, 3" D/P back zorst, 270bhp and 260ftlb :rock:
    Triumph Daytona 955i - mmmmmm :fire:
    80 dag dag :driving:
  • Greenm3
    • Jul 2004
    • 512
    I had the same symptoms, found it was a Vacum hose had come off the back off the manifold. Check the vacum lines there or on the WGFV.
    HTH
    Michael
    • Animal Mother
      • Jul 2007
      • 1135
      Where is the WGFV?
      • topsparky
        • Oct 2005
        • 2014
        Originally posted by Animal Mother
        Where is the WGFV?
        on the maf hose near the driver's side headlight
        it's a bitch to get to on an s2 a bit easier on an s4 though
        1. SHORT SHIFT KIT
        2. PORSCHE CAYENNE CALIPERS
        3. H & R SPRINGS
        4. BILSTEIN SHOXS
        5. NEW BUSHES AND HP2 STRUTS
        8. fmic fitted
        • GT500
          • Jun 2006
          • 2181
          I bet your dump valve is knobbed! Diaphram splits and starts a low wuffle.
          Rob..
          87 UR 20v ABY
          97 S6 Avant
            Dump valve. Mine sounded like an S1 at Combe when I came off the track! Loved it but it's not too good for the car so best to change it. Bosch 710N (Audi S3) one is more modern than the OEM S2 and a lot of people run them (including me). Should be less than £25 from VAG Parts. Or you can buy a leaking Forge one and get a sarcastic letter when you send it back for £80... the choice is yours!
            • Billman
              • 4129
              I think it is turbo stall.
              Go Holset or Go RS4
              • Animal Mother
                • Jul 2007
                • 1135
                A bailey DV30 is on the way!
                  Good work, not sure what they're like so please report your opinions on it when you get it. Hope it solves your problems.
                  • dest
                    • 4287
                    Its not wastegate chatter, its air rushing back over the turbine blades which can then cause it to stall.
                    Sounds great, but not good in the long run!
                    • Animal Mother
                      • Jul 2007
                      • 1135
                      Thought so, don't facy chewing up my turbines. Mr Bailey will be here soon.
                      • Animal Mother
                        • Jul 2007
                        • 1135
                        Mr Bailey arrived today.
                        • Animal Mother
                          • Jul 2007
                          • 1135
                          BUT, I went to fit it and found this little beauty
                          I was pleased as you can imagine, well, at least I know what the problem is now!
                          • Animal Mother
                            • Jul 2007
                            • 1135
                            Any ideas?. Will an "easy out" fix it or are they pressed in? ANyone got a spare one I could have pls?
                            • S-Express
                              • Nov 2006
                              • 1133
                              It will be a standard brass hose tail - probably bsp thread??
                              You could do with a reverse drill bit type thingie to get that out....
