Water hose on the back of the engine block, part no.?
  • Jonas_R
    • 3780
    • Country: Denmark
    Seems that the big water hose, that connects to the back of the engine block seems to be leaking. Anybody that can help with a part no. or can tell me where to look in etka? Can seem to find that damn hose.
    Jonas
    Sleeper S2 Avant +450
    A6 Avant 2.7t Stage 3
    Audi S2 Coupe RS2'ed
    One of the two water matrix hoses you mean ?
    I have those BOTH spare in Samco blue if you like... Rest of the water kit to match that is on order if you like.
    Paul
    • Jonas_R
      • 3780
      • Country: Denmark
      I dont know, that is the problem
      Think I need to take a picture, so that I can show which hose I mean
      Jonas
      • Graham
        • 1622
        There is a plastic nipple adapter on the back of the block just above the gearbox, my etka is down at the moment so i cannot find the number. Its only cheap though about 13 quid IIRC
        • Jonas_R
          • 3780
          • Country: Denmark
          Yups that is the one, the plastic nipple is leaking to or maybe it actually is the nipple that is leaking. I have been looking through etka for that damn nipple but I cant find it
          Jonas
            I'm lost here - need a photo to help me find this.
            Paul
            • Graham
              • 1622
              Its held in with one M6 bolt and the plastic perrishes/goes brittle and as mine did crack off. Every water component on the car with exception of the heater matrix has failed in the last 2 years. My expansion bottle isnt far from letting go as it has a few hair line cracks. But it only costs $40 (16 quid)over here for some unknown reason.
              • Jas11n
                • 5067
                Maybe Graham can pick out the part from the FA diagrams?
                There is a few differences of the hoses to the heater matrix, air-con cars, non air-con and changes at certain chassis numbers.
                Cooling;
                Heat exchanger;
                2001 Avus Silver B5 RS4.
                1995 S2 Coupe - sold (sniff)
                • 220bhp
                  • 2578
                  If its the plastic nipple that Grahams talking about the part no is 034121143E I think it comes with an o ring. The earlier cars had a metel one, much better if you can get one.
                  Lou
                  • Jonas_R
                    • 3780
                    • Country: Denmark
                    Yeah that is part no. 33 on the picture, seems that it comes in to different version. But thanks for the help.
                    • Jonas_R
                      • 3780
                      • Country: Denmark
                      Paul do you have the hose that connects to no 33 on the picture? If yes how much is it? And do you have it in black?
                      Jonas
                      • mcandmar
                        • Apr 2004
                        • 5118
                        Lou
                        7A's have the metal version but they corrode like crazy. Best stick with the plastic version IMO.
                        91CQ20v - Gone to a new home
                        93UR-S4 - The Magic Carpet
                        94S2Bus - The Emerald Express
                          OHhhhhhhhhhhh - *THAT* nipple - yey that stock plastic bleed nipple is orrible - I broke my original by looking at it. On the Samco kit I got them to integrate a metal bleed screw with O-ring on that matrix hose. I only have a Blue one going spare... Aren't your Boost hoses Blue already Jonas ?
                          Paul
                            PS - One of the Samco matrix hoses needs modified by having a section cut out of it on cars equipped with the digital climate control system (thats nobody in the UK).
                            Paul
                            • Jonas_R
                              • 3780
                              • Country: Denmark
                              Hi Paul,
                              Iam pretty sure it is not the bleed nipple we are talking about The bleed nipple is located just where the hose comes in/out from the heater matrix inside the car.
                              This plastic nipple is located on the engine block.
                              /Jonas
