Has anone ever use one of those, I am looking into an s256 at the moment with twin entry turbine. It is supposed to be a realy good turbo. Here is a quote from September 2006 Issue of DSport magazine...
"What’s Better Than A Ball Bearing?
Introducing the new Scwhitzer/Borg Warner S200 and S300 turbocharger, with its Extended Tip Technology, it sports one of the best looking compressor maps we’ve ever seen. The Extended Tip Technology together with a Map Width Enhancement Groover allows this turbocharger to support one of the highest pressure ratios available today. This new extended tip compressor design maximizes flow while minimizing rotating weight and inertia. This unit offers a compete aero package for unbeatable horsepower and uncompromising spool up.
and here is a map for S256.
What do you think of such a turbo???
Thanks.
Thanks.
, well I hope so. What do you think about that... If I want to crank the boost up at lower rpm, I would have a good range...The map is one of a S256.
