Hi,
I have been reading some threads regarding the RS2 cam pulley setting and moving it 1 tooth anti-clockwise (Using a ADU waterpump with 26 teeth).
However on my new ADU setup (ADU sw + ADU nockers + ADU cam pulley) I have the ABY waterpump fitted, together with the ABY Cam belt. How should I set the cam-pulley timing? On mark, or slightly adjusted?
Thanks for your help.
