Newsh Stroker Project
  • Acidburn
    replied
    He's selling iirc as he commented in a different thread it was for sale.
  • repo
    replied
    Yes, tall block is the key here. Tall block requires long rod. 144mm is not considered as such.
    144mm rod and 95.5 stroke crank are not compatible. Most certainly not for 1000hp, sad but true.
    replied
    Oh come on Jamo, you know you want to sell it to me
    I need to start doing the research but to start with I need to chose between the diesel and crank or the stock block with crank and rebore and what rods/pistons etc..
    Iceland man are you selling? Or just bragging??
  • magarv
    replied
    Originally posted by repo
    And no, one 1000hp pull on dyno, before/while explosion is not evidence.
    Wrong!!!!! Jonus have done it twice.
    Once in 2006 with the old 1065hp, with racefuel/nos with the engine in the old green 90q
    Once in 2007 with 1008hp, e85 without nos and 1255hp with nos/racefuel. Actual the highest measured hp was 1285hp, but they had to abandon that pull because it leaned out. They made the 1255hp pull later same day with an extra fuel pump in the system.
    I know KRB had a 1033hp pull, e85 without nos, but that ended as you say with explosion and broken crancshaft.
    But they are all "tall blocks" (TDI)
    Both in VS Motors Dyno.
    replied
    So the above engine is a 95.5mm crank in a standard 220mm block?
    Different kind of stroker works the same but reduced rpm limit http://www.motorgeek.com/phpBB2/viewtopic.php?t=15035
    Depends Newsh, what kind of stroker are you looking for? the 220mm standard or the diesel 236mm tall block?
  • repo
    replied
    I would love to see bulletproof evidence of 1000hp taken out of stroker with 144mm rods.
    Even 500hp sounds too much.
  • urquattro-island
    replied
    2,6ltr
    Originally posted by newsh
    Anyone got a stroker engine they want to sell? Or any parts, unfinished project etc?
    here are some figures on my new built engines, the one is 2,5ltr and the other is 2,6ltr
    Diesel crank and blueprinted engines with certificate.
    144 mm conrods
    95.5 stroke
    82mm bor 83 mm bor
    Je pistons
    scat and eagle forged rods
    arp bolts
    coated bearings
    new oil pumps
    engines built for 1000hp.
  • urquattro-island
    replied
    i
    have a blueprinted stroker..
    replied
    Not me
  • terrybullwon
    replied
    And heres the pills
    I have a 2.5L eurovan block, crank, rods. Its all in very good condition. I purchased it from Blizcat a while back. I also have a set of Forged 159mm pauter rods that are new in box. All you need is a set of pistons any you have a killer 2.6L shortblock set. $1100 firm Located in Portland...
  • terrybullwon
    replied
    Originally posted by s2_bo
    Blimey John. you going for massive power now too ??
    The virus is spreading
  • s2_bo
    replied
    started a topic Newsh Stroker Project
