Newsh Stroker Project
    Anyone got a stroker engine they want to sell? Or any parts, unfinished project etc?
  • s2_bo
    • Oct 2005
    • 6067
    Blimey John. you going for massive power now too ??
    91 S2 coupé - RIP
    98 S8 - Luxury barge
    • terrybullwon
      • Mar 2006
      • 8782
      The virus is spreading
      Chef
      • terrybullwon
        • Mar 2006
        • 8782
        And heres the pills
        I have a 2.5L eurovan block, crank, rods. Its all in very good condition. I purchased it from Blizcat a while back. I also have a set of Forged 159mm pauter rods that are new in box. All you need is a set of pistons any you have a killer 2.6L shortblock set. $1100 firm Located in Portland...
        Chef
          Not me
          • urquattro-island
            • Mar 2006
            • 1915
            • Home: Norway Current: Iceland
            i
            have a blueprinted stroker..
            japanischer industriabfall nein danke!!
            www.rackeltrim.se Icelandic Division
            • urquattro-island
              • Mar 2006
              • 1915
              2,6ltr
              here are some figures on my new built engines, the one is 2,5ltr and the other is 2,6ltr
              Diesel crank and blueprinted engines with certificate.
              144 mm conrods
              95.5 stroke
              82mm bor 83 mm bor
              Je pistons
              scat and eagle forged rods
              arp bolts
              coated bearings
              new oil pumps
              engines built for 1000hp.
              • repo
                • Dec 2004
                • 893
                I would love to see bulletproof evidence of 1000hp taken out of stroker with 144mm rods.
                Even 500hp sounds too much.
                And no, one 1000hp pull on dyno, before/while explosion is not evidence.
                  So the above engine is a 95.5mm crank in a standard 220mm block?
                  Different kind of stroker works the same but reduced rpm limit http://www.motorgeek.com/phpBB2/viewtopic.php?t=15035
                  Depends Newsh, what kind of stroker are you looking for? the 220mm standard or the diesel 236mm tall block?
                  • magarv
                    • Jul 2004
                    • 323
                    • Home: Norway
                    Wrong!!!!! Jonus have done it twice.
                    Once in 2006 with the old 1065hp, with racefuel/nos with the engine in the old green 90q
                    Once in 2007 with 1008hp, e85 without nos and 1255hp with nos/racefuel. Actual the highest measured hp was 1285hp, but they had to abandon that pull because it leaned out. They made the 1255hp pull later same day with an extra fuel pump in the system.
                    I know KRB had a 1033hp pull, e85 without nos, but that ended as you say with explosion and broken crancshaft.
                    But they are all "tall blocks" (TDI)
                    Both in VS Motors Dyno.
                    "Ring addicted"
                    8,43 BTG with trafic and roadworks:http://www.youtube.com/watch?v=pYg50Bg2lVQ
                      Oh come on Jamo, you know you want to sell it to me
                      I need to start doing the research but to start with I need to chose between the diesel and crank or the stock block with crank and rebore and what rods/pistons etc..
                      Iceland man are you selling? Or just bragging??
                      • repo
                        • Dec 2004
                        • 893
                        Yes, tall block is the key here. Tall block requires long rod. 144mm is not considered as such.
                        144mm rod and 95.5 stroke crank are not compatible. Most certainly not for 1000hp, sad but true.
                        • Acidburn
                          • 13459
                          He's selling iirc as he commented in a different thread it was for sale.
                            I'm leaning towards tall block but not entirely sure of the pros and cons, I guess there's more mods and fiddling about with the tall block..
                            I want big torque and midrange.
                              Give me a shout it you want, your block choice is going to be key and how much you want to spend.
                              If you want to use your standard 220mm block I would advise a 92.8mm crank from 034 and go the way of this and you keep your rev range http://www.motorgeek.com/phpBB2/viewtopic.php?t=4966
                              I don't like the short piston compression height that is required to run the 95.5 in the 220mm block.
