If I remember correctly those two top plugs on the last picture are for the speedo and reversing light and should feed back to the gearbox, I think I got stuck on the same two during my conversion
3B wiring loom help
Well spotted - you could be right !Paul Nugent
first two not used
two black ones are speed sensor and reverse switch, (reverse switch is moved on 6 side boxes to the other side by the way)
if you needa lift i work in holmes chapel which isnt to far from the wirral (chester) give me a bell if you want a lift
07976299409
cheers
will
Thanks for offer and help from everyone. Once I have removed this 7A, 5 speed gearbox and the present loom I may give you a call. Also fitting a CGR 6 speed without having to alter bodywork at the same time and retaining my cable speedo so a lot of work required.1986 Coupe q - 2281cc 3B, chargecooler, 2.75" exh & downpipe, ported head, water injection, CGR box, modified MD357 turbo, 440cc injectors, high power coil.
2004 A4 2.5TDi convertible, re-mapped to 180bhp
2011 A5 sportback 3TDi-Backbox delete, remapComment
