The flames will be side effect of richness alright - especially so as you are deCATTed.
Might be worth checking your fuel pressure regulator - you should see 4bar on the rail, less whatever vacuum it pulls if testing on idle of course.
Fuel pressure should be 4bar ABOVE manifold pressure at all times... MIght be worth getting injectors checked out too. If they aren't flowing properly or turning off too slowly then your getting more fuel than you should.
MAFs are tricky beasts - they normally degrade in such a way that they produce lower indications of the amount of air coming into engine... WHich is OK in cruise as the closed loop lambda system corrects mixture for that (within limits). On WOT, lamdba is ignored and so you should be injecting less fuel than required air. So its weird that you seem rich.
Then again - you say it drives fine and was not massively outrun by a similar spec car (you are heavier for starters) so its odd the dyno result doesn't back that up.
COuld the intake temps be very high on the rollers ?
Paul
Paul
