KV/MB/MC/3B/ABY compatability
  • Ian Simmonds
    • Jun 2005
    • 2858
    Originally posted by Jon441cc
    You mean if i trawl through all of motorgeeks project threads i would find this
    http://motorgeek.com/phpBB2/gallery2...2_itemId=41111
    That looks like a PITA, what about reducing/modifying the head side?
    93 MTMS2 Avant
    • Flat on my back
      • Jan 2007
      • 2449
      You dont want to restrict the flow of water through the head, and your going for more power therefore more heat.
      Also easier to find a welder to do the block (iron) as opposed to alloy heads...far easier to get wrong.
      Carlos.
      • Ian Simmonds
        • Jun 2005
        • 2858
        True...
        Fortunately, I'm hoping if I keep my 034 103 351G KV head (same as MB/MC) attached to it's KV bottom end with new rods/pistons there will be no gallery alignment issues. Unfortunately that's not a lot of help for Jon with the 20v though.
        93 MTMS2 Avant
        • Flat on my back
          • Jan 2007
          • 2449
          As post 9...
          Overhaul the block and head, bigger IC and modern turbo, standalone ecu and you'll get a storming lump.
          Everyday driver 4-450 hp @ crank is more than enough?
          Carlos.
          • Jon441cc
            • Dec 2005
            • 2061
            I have a KV head i need to get rid of Ian if you need it
            Talking about cooling cylinder heads, there is a great mod for better cooling of a 10v head on Motorgeek, i will post it up when i find it.
            • Ian Simmonds
              • Jun 2005
              • 2858
              Really?.... Blimey ... even a genuine 300/320bhp will be rapid with the low geared 016 CQ box... That'll be a good start for the A2 replica project..
              93 MTMS2 Avant
              • Ian Simmonds
                • Jun 2005
                • 2858
                Thanks for the offer Jon, I'm okay at the moment, I've got an MC and a KV head. Would like to see that post too... I think I might be possibly generating a bit more heat than anticipated.
                93 MTMS2 Avant
                • Jon441cc
                  • Dec 2005
                  • 2061
                  Here we go
                  • Ian Simmonds
                    • Jun 2005
                    • 2858
                    Thanks Jon... Copied and pasted the pic to my 'project' folder.
                    93 MTMS2 Avant
                    • BahoSSS
                      • Aug 2007
                      • 26
                      • Country: Russian Federation
                      #25
                      what's the cost of converting KV block to 3B analog????
                      as i understand, we only need oil cooling???
                      • Ian Simmonds
                        • Jun 2005
                        • 2858
                        To go to the 20v head (3B) I think you'll have to attempt the same water gallery modification to the block that Jon441 has done, together with the additional oil spray jets.
                        93 MTMS2 Avant
                        • BahoSSS
                          • Aug 2007
                          • 26
                          #27
                          additional oil spray jets - i think it's hard to do something with it...
                          any ideas?
