Hey guys, I'm planning on starting a project soon, but I have a couple of things I want to get straight before starting. I know this is an S2 forum and all, but hey its a 20VT project, so here goes:
I own a 85 coupé quattro type85, currently with the stock 2.2 5cyl KV engine (136 hp) and would like to swap that one out for an AAN S4 engine which I picked up yesterday. I have some friends who happen to be pretty competent mechanics helping me out so the installation shouldn't be that much of a problem. Just some things I want to clear up before starting.
- Battery. Does it need to be relocated to the rear/boot of the car, for extra clearance of the wastegate etc. Like with a 10VT swap?
- Gearbox. From what I read, can be used and can handle the increased power with ease?
- Oil cooler. Any suggestions on where to place it? Does it HAVE to be in driving wind?
- Intercooler. I have a stock RS4 aluminium intercooler, should be sufficient I think? Placing will need some modifying I think when looking at the air intake of the AAN. A front mount won't be possible with this one I think.
- Airbox/filter. Can I use the stock AAN airbox, seems a bit large, any suggestions?
- Braking. If I understand correctly the S4 uses vacuum-assisted braking whilst the type85 does not? How to convert it to work properly?
- Motormounts. Direct fit?
- Exhaust. Downpipe can be made fit to by the looks of it, but is the diameter of the stock exhaust system sufficient, or is it too restrictive?
- Any other (mechanical) modifications I haven't thought of?
Sorry for the load of questions, any help would be appreciated. Merry Christmas to you all.
