Hi,
Have a Audi 90q that needs a upgrade in the engine dep, and the 7A engine is being replaced by a 3b engine. The 3b engine with wiring and such was taken out from a running S2, and everything was working well before the engine and wiring was removed. Now, in the 90, it wont start. We have located the problem to be the fuel injectors that dont open for any fuel. Our theory is that this is because the ECU wont send the trigger signal that is needed for the fuel pump relay to open properly.
By looking at this schematic from S2central, it looks like the fuel pump relay needs a trigger signal from ECU pin #3. We belive that this seems to be the problem, as nothing changes at that pin when we turn the ignition on or try to start it..
Does anyone have a clue why the ECU wont trigger it? Everything is lined up properly, and we have sparks at all plugs. The relay is tested and seems to be okay..
........ ehh no, no life signs
