How long will 1&5 piston last running this sort of power.
I dont want to take the head off until I really have to. I know for a fact that 1 or more studs will break removing the exhaust manifold.
Will the above be pushing my luck to far.
When u take off the head off skim it before putting back together r u using adjustable cam pulleys? just thinking it was needed on the cossie as the head was closer to the block so the timing was out. I am sure it was not by much but just wondering .
cheers
Paul
cheers
Paul
Not sure on the long term effects of doing this, but to be honest you would be better off running with the RS2 manifold. I think 360-380 maybe a bit out of range for the std manifold.
now I work in one of the UK's biggest VAG trade centres!!
