ABY versus 3B Ecu pinout
  • 4WheelDrifter
    replied
    Originally posted by Pirvu Eugen
    Lost?
    Sorry to hear this!
    I think we will not start the engines for the first time in the same time!
    I can try to be the guineea pig!
    Iff something goes wrong... I can say to you STOP!!!
    Will not hapend!
    I am sure!
    I have also only 1 ECU!
    You can be the guinea pig. I like that idea.
  • Pirvu Eugen
    replied
    Lost?
    Sorry to hear this!
    Will not hapend!
    I am sure!
  • 4WheelDrifter
    replied
    Thanks Eugen. We're almost there.
    I'll be pretty nervous firing the engine up for the first time. Especially as I've lost my spare ECU.
  • Pirvu Eugen
    replied
    Is the same! Is swiched power throw the fuel pump relay!
  • 4WheelDrifter
    replied
    Can anyone confirm that pin 37 is the same on the 3B/ABY/AAN/ADU? The descriptions on s2central are quite different.
    Paul, could you also update the picture used for the ABY pin-out overview, the current one is the same as the 3B.
  • Pirvu Eugen
    replied
    Sorry! I didint saw you answered allready!
    Sorry!
    Eugen
  • Pirvu Eugen
    replied
    I whanted to ask.. maibe is a diference between AAn and ABY?
    Or just a mistake in the books. Anihow is not so important... We can change the pins from there iff the engine runs in 3 cilinders..
    About the pins from AC? You know something? Please!
    All the best!
    Eugen
    replied
    My info comes from mixture of Audi literature from USA (AAN) and Europe sources. I'll check my site for typos - but there are some mistakes on the factory info.
    Paul
  • Pirvu Eugen
    replied
    This means that S2 Central is wrong.
    He can corect that iff is like this.
    what about the rpm and reference sensor signal?
    All the best!
    Eugen
  • 4WheelDrifter
    replied
    The information I have from Tommy's site says:
    Pin 1 - POS #1
    Pin 2 - POS #2
    Pin 20 - POS #4
    Pin 21 - POS #5
    Pin 23 - POS #3
    HTH
  • Pirvu Eugen
    started a topic ABY versus 3B Ecu pinout
    Hello!
    I whant to change the ecu from 3B to AAN and use the 3B loom.
    I have gathered some info about this swap but i saw some diferences between the S2 Central and SJM sites.
    Pins1 from ABY at 1 site is for output stage ignition coil nr.1 and at the other is for nr.3
    same about the pin nr.23
    Somebody knows exactly wich is wich?
    And i noticed that between the 3B and ABY the RPM and Reference sensors are in the oposite pins. This is right?
    Thank You verry much!
    All the best!
    Eugen
